trunk rattling on 96 civic need help
Old Aug 27, 2002 | 04:58 PM
xbladr's Avatar
xbladr
Default trunk rattling on 96 civic need help
I installed 2 12" subs and the rattling of my trunk is extreme. I have no clue wat it is i got that dynomat license plate thing and i even took off the license plate and it definately si not that thats rattling. I dont know what else to try i mean its friggen rediculous. What should i do any suggestions would be great.
Old Aug 27, 2002 | 08:02 PM
smokedogg's Avatar
smokedogg
get a roll of dynamat and line the trunk panels. that usually does the trick.
Old Aug 27, 2002 | 08:14 PM
93acuraviga's Avatar
93acuraviga
Yep I have that same problem with my acura, it seems like its not so much the trunk rattling, as inbetween my back window and the back deck. I just shoved a towel between it and it helped a bit, but the trunk lid still rattles. Try it, it's a cheap way to cut down on the rattling. I'll probably end up doin the dynamat thing too though cause its just too annoying.
Old Aug 28, 2002 | 08:25 PM
civic_dude's Avatar
civic_dude
i dynamated my trunk and it helped alot, also i agree on using towels or even old t-shirts to put in problem areas, i even wraped my toold and car jack equipment. later
Old Aug 30, 2002 | 05:54 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
I use the triple threat...lol
1. foam sealant
2. rubberizing spray
3. sound dampening sheets
Old Aug 30, 2002 | 08:52 PM
arch iceman's Avatar
arch iceman
Really its hard to say until you isolate the problem. Lean on the trunk lid and see if it still rattles with your added body mass. If it does, it can be solved with a layer of Dynamat.
Your rear deck could also be rattling, third brake light, and rear seatbelt mechanisms. Do you have a spoiler?
Old Aug 30, 2002 | 10:49 PM
xbladr's Avatar
xbladr
Yea i do have a spoiler and tom i will check to see if it rattles with me on the trunk thanks
Old Aug 31, 2002 | 07:04 AM
b00gers's Avatar
b00gers
your spoiler will rattle. and besides the panels in the trunk, and the rear panel, it seems like theres also something else in hondas that rattle pretty bad. it sounds like its coming from inside the gas tank.
:dunno: it doesnt bother me from the inside, but with the windows rolled up and standing out, you can hear it.
Old Sep 1, 2002 | 10:59 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
do you have a hatch or coupe?
-if it's a hatch, try stuffing the third brake light on the spoiler cause it stopped my rattling.
-if it's a coupe, did you replace your rear speakers or take off the rear deck at anytime? usually those cheap plastic tabs don't absorb enough of the vibrations and the rear deck ends up flopping back and forth.
-one other thing, where ever there are bolts or nuts holding in something to the chasis, unscrew them and place some type of dynamat to both sides. :thumbup:
Old Sep 11, 2002 | 09:58 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
rattle = lots-o-bass
learn to love it or spend money
