Power door lock wires? where are they????
Old Mar 20, 2005 | 04:14 PM
terrysoutboard's Avatar
terrysoutboard
Default Power door lock wires? where are they????
95 integra, I know its a 3 wire neg system, and I thought I had the wire colors and locations- when I test the wires I have my test light clip on a positive, I stick the supposed wire and hit the lock switch in the proper direction, I should get a ground pulse in that wire right? I cant seem to locate the 2 wires nec. to finish my alarm install. Can anyone please help???
Old Mar 21, 2005 | 05:10 AM
VPUPPY's Avatar
VPUPPY
you are right, locks in hondas are negative trigger. where are you getting the wires from? are you getting it from the drivers side kick panel off the big gray harness? if you believe it to be the correct wire, the locks should kick if you use a jumper wire connected to it on one end and on the other you touch it for a second to ground. btw, its better to use a multimeter to test wires than a test light on cars equipped with air bags - test lights can short out certain devices.
