Transmission Help (Tranny Case & Bearing Size Issue)
Old Mar 8, 2005 | 12:12 PM
BlueCrxNC's Avatar
BlueCrxNC
Default Transmission Help (Tranny Case & Bearing Size Issue)
Parts I currently have on hand for use:
89 JDM Integra ZXi
- Transmission Case
- Differential
89 USDM CRX HF
- Differential
I'm using the 1-4 gears of the ZXi (Same gears as CRX Si/DX) along with the HF 5th gear and the ZXi Final Drive (Differential Ring Gear and Countershaft) of 4.4375 which makes for a small difference in shift times.
I need to know if I can even use the ZXi case otherwise I'll have to purchase another case/tranny.
The ZXi tranny case uses the larger Differential Bearings (80 OD x 40 ID x 18 Depth) while the HF Differential used (72 OD x 35 ID x 17 Depth). Can I find a bearing that will work? (ie. 80 OD x 35 ID x 18 Depth) Is that 1mm of depth on each side going to hinder my chances of using the case (trying to save money and time)
Thanks!
John
bluecrxnc@hotmail.com
Old Mar 9, 2005 | 05:06 PM
BlueCrxNC's Avatar
BlueCrxNC
All the bearings I can find on civics/crxs are either 72mm OD with 35mm ID or 80 OD with 40mm ID. I need to find a bearing that is 80mm OD (to fit the case) and 35mm ID (to fit my differential)
Unless I can use the 35mm OD Axles in the 40mm OD Differential... Don't think I can. Swap differential internals? Not likely I think.
Old Mar 10, 2005 | 05:03 PM
BlueCrxNC's Avatar
BlueCrxNC
Anybody?
