my kitchen sink isn't working right... any ideas?
when i turn it all the way on it just comes out slowly... if it slowly turn it on, it will start to increase, but then half way up it'll make a "clunk" sound and then just start trickling again. any ideas?
this is the kinda faucet that just has one lever.. up to turn it on, left for cold water, right for hot water
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
replace your your faucet the piece that drops down when you turn the lever (internal) is loose and will only work if used slowly. either that or try and make sure all the screws are tightened on the faucet itself
take apart and inspect. something came loose, or a piece of rubber is worn out usually. you can get all the pieces to fix a faucet at any hardware store. no need to buy a whole new one unless you want a more modern looking one.
