Accord Head unit question ( and also suggestion)
Old Feb 6, 2005 | 11:37 PM
slando's Avatar
slando
Default Accord Head unit question ( and also suggestion)
Hey..
As you accord owners know the stock head unit is pretty damn big.
If i get it replaced with a regular head unit, Whats up with the other space? Is it just gonna be a big empty space??
Also I have one 12 inch rockford fosgate punch with a 800 watt amp, It sounds good but gets staticy on high.
What speakers do you guys reccomend, and how many should I get for an accord?
Also head unit suggestions, I like the ones with LED screen's.
How much will the head unit affect performance of the sound?
I dont know much about this
Old Feb 7, 2005 | 08:02 AM
Arfboy's Avatar
Arfboy
Diamond Audio turns me on
When you replace the head unit, you can get a mounting kit that will help fill up the space if the new deck isn't the same size as OEM. Here's an example: http://www.crutchfield.com/S-rz3eJ7B...00&I=120997892 .
An aftermarket deck with high voltage preouts should definitely improve the performance of your sub, as well as your speakers if you get an amp, when you turn the volume up. All you really need is to upgrade the 2 front speakers. You CAN upgrade the rear as well, but it's not necessary. The options that you have will be limited by your budget. How much are you looking to spend on all of this?
Old Feb 7, 2005 | 12:57 PM
slando's Avatar
slando
I already have an amp and a sub im just trying to make it sond better
The amp is a performance teknique 800 watt 2 channel amp.
What kind of speakers do you reccomend i really know nothing about speakers
thanx bro
I dont wanna spend more than 300
Old Feb 7, 2005 | 01:23 PM
Arfboy's Avatar
Arfboy
$300 total for both the speakers and head unit or just speakers?
