FS:Testing: 1991 Crx Si Project
Old Dec 5, 2004 | 11:43 AM
mistacee's Avatar
mistacee
Zc powered ED9
Default FS:1991 Crx Si Project
Here are the specs - 1991 Honda Crx Si
-134k on chassis
-JDM b16a1 Motor (50-60k on it)
-LS Transmission w/y1 gears
-ACT 6 Puck Clutch w/extreme pressure plate
-ACT 12.5 light flywheel,chromolly
-Driveshaft stage 2 axles
-Hasport Shift linkage w/short shifter
-Hasport Motor mounts
-New Placing Racing Crossmember w/4th motor mount
-JE 9:1 Compression
-Eagle Rods
-Knifedged Crank
-Type R Oil Pump
-Type R Water Pump
-Type R Valves,Valve Springs,Reatainers and Cams
-Brembo Stainless Steel brake lines (Fronts installed,rear ones not)
-MSD 6al Box
-MSD Blaster 2 Coil
-High Flow Cat
-2 1/2" Exhaust w/4 1/2" Muffler
-Neuspeed Race Springs
-KYB 4way (3way?) Adjustable Struts
-Neuspeed Front Upper Strut bar
-Neuspeed Lower tie bar
Story:
The car was a former turbo project car.The turbo equipment was only 3/4 there when i got the car, so I sold the parts and took it back to N/A.
The car will turn over and it does run,but it needs to be completed.Great project but needs some time to be completed,which i do not have.Needs an O ring in the oil pump,but i am having that done.Other than that,it is justa matter of re-mounting the bumper support, bumper, installing the lights/turn sigs,(all of which i have)and it's rolling.Interior is in good shape as well,and the body is in good shape too.
Lots of goodies with this car,so am asking $4000.00 OBO.
Contact me via Pm,phone or email.
Cory @ 607-533-4877
Pics:
Old Dec 6, 2004 | 01:05 PM
mistacee's Avatar
mistacee
Zc powered ED9
Bump for winter project
Old Dec 9, 2004 | 12:25 PM
mistacee's Avatar
mistacee
Zc powered ED9
I really need this to go...i don;t have the time to mess with this.
Bump for a nice Crx and good project!!
Old Dec 10, 2004 | 01:56 PM
mistacee's Avatar
mistacee
Zc powered ED9
I will also consider any reasonable offers!!
Old Dec 14, 2004 | 12:25 PM
mistacee's Avatar
mistacee
Zc powered ED9
Bump...any reasonable offers?
Old Dec 14, 2004 | 01:39 PM
Nelson's Avatar
Nelson
Administrator
** New Rule: Please Note the State of Where Vehicle is Being Sold in the TITLE
Effective 11/29/04
Please, as courtesy to potential buyers, note the state or providence of where the vehicle is located in the SUBJECT of the thread.
Example:
FS: 1998 Acura Integra; SoCal
All threads that don't follow this rule will be CLOSED.
Thank you all for your co-operation.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
