Ignition control module help me
Old Dec 3, 2004 | 10:03 PM
TriniSpeed's Avatar
TriniSpeed
Default Ignition control module help me
So as we probably all figure out by now. th ICM (ignition control module) eventually dies out without any signs of disaster. It has happened to all of my friends with every type of honda. Now I guess it is my turn. Does anyone know which module I need? There are two at the shop that I go too. One that uses 2 holes to bolt up which is 86 dollars then there is the one that uses 3 holes that is 169. I haven't taked off the rotor in the distributor but does anyone know which module I need? I am sure it is the one for 169 with my luck. Also any tips on taking off that damn bolt that holds on the rotor?
Please help
Old Dec 3, 2004 | 11:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Are you talking about the distributor?
Old Dec 4, 2004 | 10:34 AM
Tobra's Avatar
Tobra
The little screw that holds the rotor on is plastic(Has to be non conductive, or non magnetic I guess), buy a new one if you remove it. Did you check your ignition coil with an ohm meter? I would use the OEM parts for that stuff myself, it is very possible that they use a different ICM for the B18B and the B18C motors.
