Leaking oil from valve cover
Old Dec 2, 2004 | 07:11 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Default Leaking oil from valve cover
So when I was working on my car, I noticed oil leaking out of the left side of the valve cover, bumper side. What could cause this? Faulty valve cover gasket? It shouldn't be hard to replace right?
Old Dec 2, 2004 | 09:38 PM
GSR4444's Avatar
GSR4444
possibly the valve cover gasket. really easy to replace.
Old Dec 2, 2004 | 09:58 PM
dubcac's Avatar
dubcac
I
It's easy dom...couple 10mm bolts and some hondabond. Should take about 10 mins.
Old Dec 2, 2004 | 10:04 PM
dom93hatch's Avatar
dom93hatch
Brett:
Vincent said the valve cover studs are sensitive and overtorquing them could ruin the gasket. Any troof to this? Do you have torque specs?
Old Dec 2, 2004 | 10:45 PM
Singhg83's Avatar
Singhg83
BALLIN'
damn,
i have the same problem.
i would also like to know the torquing amount.
Old Dec 2, 2004 | 10:58 PM
slater442w30's Avatar
slater442w30
Honda newbie
Also while you have the cover off you want to replace the spark plug seals in the valve cover if it has them.
Old Dec 2, 2004 | 11:22 PM
dubcac's Avatar
dubcac
I
You don't need to tighten them much. Overtorquing won't ruin the gasket, but it can snap the the studs that the bolts go onto. Since the bolts have the little seals underneath them, you just need to get them until they are tight. I don't know the torque spec off hand, but once they get tight with a rachet, stop.
