Would a turbo from....
Old Nov 30, 2004 | 06:51 PM
Kabooki's Avatar
Kabooki
Default Would a turbo from....
a 1st gen eclipse work on a civic? someone is selling one on ebay for cheap. will i need a special manifold? I know nothing about the eclipses
Old Nov 30, 2004 | 07:04 PM
Paulll's Avatar
Paulll
Hail Bent
you've been here long enough to search...
Old Nov 30, 2004 | 07:50 PM
Kabooki's Avatar
Kabooki
im not touchin that --> [SEARCH]
.....its evil...
Old Nov 30, 2004 | 07:55 PM
prelood's Avatar
prelood
Dont hold me to this, but I think you can, its just really weak...
I really dont know much about it at all
Old Nov 30, 2004 | 09:42 PM
2gr84u's Avatar
2gr84u
2gr84u
the 14bs from the the 1st gens arnt bad, as for wether it will fit or not, anything will fit if you do enough to it :P
Old Nov 30, 2004 | 10:03 PM
Skad's Avatar
Skad
Worst Poster Eva
using a trash comcactor to make the 1st gen eclipse turbo smaller for fitment issues is a pretty good idea..
Old Dec 1, 2004 | 01:14 AM
Civic2Scooby's Avatar
Civic2Scooby
all you gotta do is get the proper flange.
Old Dec 1, 2004 | 01:18 AM
Kabooki's Avatar
Kabooki
the biggest thing im unsure about on a turbo is how one would tap into the oil line and dunno anythin about the cooling line either
Old Dec 1, 2004 | 10:42 AM
SurfNSB's Avatar
SurfNSB
From what I understand the 14b is actually a pretty common choice for people doing junkyard setups on their civics.
Old Dec 1, 2004 | 10:47 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
yes you can fit a 14b turbo onto your civic. the manifold you need depends on whether you have a d,b,h,k series motor. so please specify.
oil isnt a problem. you have two options as to what you can do.
A: get a golden eagle oil sandwich adapter. this sits in between the oil filter and block and has two bungs, in which u can run oil lines from. i got mine from...
http://www.robearracing.com/pd_golden_eagle_vtec_conversion.cfm
B: you remove your oil sensor in the back of your block, get a brass T, and run a line from there.
