Would a turbo from....
Originally Posted by Kabooki
a 1st gen eclipse work on a civic? someone is selling one on ebay for cheap. will i need a special manifold? I know nothing about the eclipses
yes you can fit a 14b turbo onto your civic. the manifold you need depends on whether you have a d,b,h,k series motor. so please specify.
oil isnt a problem. you have two options as to what you can do.
A: get a golden eagle oil sandwich adapter. this sits in between the oil filter and block and has two bungs, in which u can run oil lines from. i got mine from...
http://www.robearracing.com/pd_golden_eagle_vtec_conversion.cfm
B: you remove your oil sensor in the back of your block, get a brass T, and run a line from there.
the biggest thing im unsure about on a turbo is how one would tap into the oil line and dunno anythin about the cooling line either
