won't hold idle on startup
Old Nov 21, 2004 | 10:25 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Default won't hold idle on startup
I have a '94 GSR and just recently the car has been running poorly. When I go to start the car after its been sitting for a while (overnight or something), it doesn't want to hold idle and will even dip as low as 200 rpm before puttering around and wanting to die. I usually will hold the revs at 1500-2000 rpm for like 30 seconds to let the car kind of warm up. This seems to help a little bit but only until after the car has been run for a few minutes. I don't seem to have this problem as much later in the day, when its not as cold and when I have already driven the car that day. Could this be the Idle Air Control Valve or something else? Would resetting the ECU help at all? (I am running a Skunk2 ECU and recently swapped stock cams back in for my Type R's). Thanks.
Old Nov 19, 2005 | 11:46 AM
R_Squared's Avatar
R_Squared
LEVEL UP
same problem a year later...any ideas?
Old Nov 19, 2005 | 12:45 PM
sherwood's Avatar
sherwood
I missed Sean
the motor is just cold. it could be a bunch of things, basically anything that might be outside of operating temperature (ths dizzy, the spark plugs, etc.)
my un-educated guess might be something to do witht he engine getting spark
Old Nov 19, 2005 | 05:09 PM
dubcac's Avatar
dubcac
I
Since it happens during warm up, I'd check the fast idle thermo valve.
