Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Integra & 97-01 Integra Type-R (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r-17/)
-   -   won't hold idle on startup (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r/165266-wont-hold-idle-on-startup.html)
R_Squared Nov 21, 2004 10:25 AM
I have a '94 GSR and just recently the car has been running poorly. When I go to start the car after its been sitting for a while (overnight or something), it doesn't want to hold idle and will even dip as low as 200 rpm before puttering around and wanting to die. I usually will hold the revs at 1500-2000 rpm for like 30 seconds to let the car kind of warm up. This seems to help a little bit but only until after the car has been run for a few minutes. I don't seem to have this problem as much later in the day, when its not as cold and when I have already driven the car that day. Could this be the Idle Air Control Valve or something else? Would resetting the ECU help at all? (I am running a Skunk2 ECU and recently swapped stock cams back in for my Type R's). Thanks.
R_Squared Nov 19, 2005 11:46 AM
same problem a year later...any ideas?
sherwood Nov 19, 2005 12:45 PM
the motor is just cold. it could be a bunch of things, basically anything that might be outside of operating temperature (ths dizzy, the spark plugs, etc.)
my un-educated guess might be something to do witht he engine getting spark
dubcac Nov 19, 2005 05:09 PM
Since it happens during warm up, I'd check the fast idle thermo valve.
© 2026 MH Sub I, LLC dba Internet Brands
