help! gears grinding
Old Nov 18, 2004 | 11:39 PM
theguy387's Avatar
theguy387
Default help! gears grinding
I have a 97 gsr with a 94 gsr motor. ever since I took the car up to 130 plus on the freeway my gears have really been struggling to go in. I have the clutch all the way in and the gears still will either struggle to go in or will grind. is this my clutch or my tranny that is going or gone. fyi I just did an oil change on the car and replaced tranny oil. resevoir is still full for the master cylinder. please help. teggy is in pain.
Old Nov 19, 2004 | 12:01 AM
xIntegrax's Avatar
xIntegrax
u are going 130 mph on the freeway and your shifting gear? if u pass 100 mph, wouldnt you be in 5th gear already?
Old Nov 19, 2004 | 12:16 AM
theguy387's Avatar
theguy387
I was I was already like at 65k but I was wondering if maybe that had something to do with maybe burning out the clutch or messing with the tranny.
Old Nov 19, 2004 | 07:56 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
If it is all the gears, it is most likely the clutch. If it is just one or two gears, it is most likely the synchos.
Old Nov 19, 2004 | 10:32 AM
newgsrdriver's Avatar
newgsrdriver
Exactly. If it gets worse and worse...where first its a bit notchy, then it gets tough, then real hard then it could be a fluid issue. But if you ran the car hard then all of a sudden feel its tough to go into gear, its probably a clutch issue. If its only a specific gear, look to your syncro.
Old Nov 19, 2004 | 11:02 AM
kfar09's Avatar
kfar09
probably is the clutch but im pretty sure going from 65-130 (NOT SMART BTW) doesn't cause any strain on the clutch. the clutch is only "worn down" when slipping the clutch while shifting. correct me if im wrong
but hopefully everything works out. if a new clutch is in order, then great. upgrade so you can hold more power in the future!
Old Nov 19, 2004 | 05:24 PM
Tobra's Avatar
Tobra
Perhaps you just took the tranny fluid beyond its useful life.
Old Nov 20, 2004 | 01:56 AM
theguy387's Avatar
theguy387
any feedback on that new centerforce double sided clutch. (you know the regular on one side then six puck on the other?.) kinda in a budget so was thinking stock clutch and re surficing flywheel.
Old Nov 20, 2004 | 10:55 AM
kfar09's Avatar
kfar09
go with an ACT HDSS, holds up to 243ft/lbs of torque and doesn't cost that much.
Old Nov 21, 2004 | 03:33 PM
rslsgsr's Avatar
rslsgsr
poor hungry dirt kid
or... you could go with exedy... its cheaper too
