Almost done and :madfawk:
Old Nov 9, 2004 | 09:41 PM
dustimus's Avatar
dustimus
Better golfer than you
Default Almost done and :madfawk:
Well I hit this little snag at the end of my little DIY. Bolt snapped off when I was torqueing it down.
I was thinking, just get a drill bit, some PB blaster and have at it until I can get a flat head in and turn it??
File Type: jpg
Old Nov 10, 2004 | 11:59 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Negative, it has to be drilled a re-tapped, but then again I have no clue what I am looking at, it's too close up.
Old Nov 10, 2004 | 12:41 PM
dubcac's Avatar
dubcac
I
Looks like a cam cap bolt. Gotta drill out the bolt and retap it if the threads are damaged. Be very careful when tightening these bolts, do not go over the recommended torque limit.
Old Nov 10, 2004 | 02:34 PM
dustimus's Avatar
dustimus
Its the far right exhuast cam cap. The bottom right smaller bolt. Do I really need it??? The bolt next to it holds it down flush. I really don't have the time and resources for this.
Old Nov 10, 2004 | 03:24 PM
mslate's Avatar
mslate
I would try a reverse drill bit and then a bolt extractor. If it broke because you over tightened it, it will probably come out fairly easy.
Old Nov 10, 2004 | 04:15 PM
dubcac's Avatar
dubcac
I
Yes, you really need it.
:werd:
Hopefully this will work.
Old Nov 10, 2004 | 04:37 PM
teg92's Avatar
teg92
WHAT OK YEAH!
drill and re-tap a new whole its not that hard
