B20b?
Old Nov 5, 2004 | 08:15 AM
MoBiX's Avatar
MoBiX
©ªŘs!
Default B20b?
Is the B20B a good engine, if so, will it fit into a 94 civic ex?
Old Nov 5, 2004 | 09:26 AM
dubcac's Avatar
dubcac
I
Yes, yes.
Old Nov 25, 2004 | 12:43 PM
sherwood's Avatar
sherwood
I missed Sean
b20 is a b18 overbored to 84mm with a b16 non vtec head. it's a good engine for just the swap, alot of torque that the ohter b-series are missing
Old Nov 25, 2004 | 12:58 PM
Snoopy's Avatar
Snoopy
been there done that
there is no b16 non vtec head :screwy:
the b20 is a b18b bored out to 84mm. thats all.
Old Nov 25, 2004 | 01:13 PM
sherwood's Avatar
sherwood
I missed Sean
i'm not really a b-series guy, i could have sworn it was a b16 head cause i thought that the ls was a b16 non vtec , but it is a b18 non vtec
i still think that it is a ls head
Old Nov 26, 2004 | 12:29 PM
Snoopy's Avatar
Snoopy
i dont understand what you're trying to say
Old Nov 26, 2004 | 12:40 PM
BoostedITR41's Avatar
BoostedITR41
the B20 head is the WORST flowing honda head out there and since the block is bored to 84mm the cylinder walls are pretty thin
Old Nov 26, 2004 | 02:12 PM
Civic2Scooby's Avatar
Civic2Scooby
its the same head as the b18b...and if you arent boosting it, then the thinner walls isnt really a big concern
Old Jan 2, 2005 | 10:44 PM
twinring's Avatar
twinring
the top short block is a B20b from a JDM stepwagon. (not available in the US)
the bottom block is a B16a from a JDM EK civic sir. notice the webbing on the B16a is more substantial. its really buildt for high RPM. the B20 doesnt have piston squirters which also limits its ability to perform at hi RPM.
you cant tell by these pics but the B20 cylinder walls are thicker than the B16as if you measure them but they are "thinner" relative to the size of the piston and stroke.
This B20 will be rebuilt and put into my 92 JDM Civic Sir II. i love the B16a but I need more torque which is real world street power. The B16a just doesnt have much torque because of its short stroke.
hope this helps
File Type: jpg
Old Jan 3, 2005 | 09:54 PM
bambbrose's Avatar
bambbrose
b20 sleeves are not bored b18 sleeves.. they are a webbed cast sleeve design, which is completely different from all other b series engines, and is prone to cracking at high compression/rpm levels
