94' LS Shifter / Syncro problems
Old Nov 1, 2004 | 04:45 PM
slapmaho's Avatar
slapmaho
Default 94' LS Shifter / Syncro problems
I am having trouble on the 1/4 mile shifting from first to second
when i take it up to 7000rpm's and shift into second rapidly it does
a soft grind and than goes into gear, if i shift slightly slower it feels
like it has two steps to get into second but goes,
all the other gears do not have this problem.
my clutch is in good condition also.
any help please!
also we had a really hard rain lately and my alarm system all of a sudden
stopped responding and my amps went out, now my amps came back
but no alarm.
thanks
Old Nov 1, 2004 | 08:26 PM
HoNdAeVo's Avatar
HoNdAeVo
I railed YOUR sister.
same thing happens in mine =/
Old Nov 2, 2004 | 05:02 AM
xfactor's Avatar
xfactor
ya i get a small grind goin into 2nd on shifts ones inawhile..........ive heard that short shifters can actually mess with your syncros if you shift too fast too often oh well new car in spring for me
Old Nov 2, 2004 | 06:14 AM
carta79's Avatar
carta79
Life after death
What is the point of even shifting at 7000 rpms?
If you shift to fast you grind synros, I can't even imagine at 7000 rpms.
I reckon the LS doesn't hardly make any power that high, so why bother.
Do your car a favor and treat it right? Or find yourself having to shell out money for transmission/engine work due to abuse.
teg92's Avatar
teg92
WHAT OK YEAH!
Try changing your transmission fluid I heard that helps with grinds, If you do change your fluid Use Honda Transmission Fluid only
Old Nov 2, 2004 | 06:47 AM
b18coupe's Avatar
b18coupe
thats normal, my car does it. get the shifter stabilizer bushings, it has helped mine
Old Nov 2, 2004 | 10:20 AM
xfactor's Avatar
xfactor
i redline my car daily at 7k haha...but my peak power is at 6800
Old Nov 3, 2004 | 06:11 AM
carta79's Avatar
carta79
Life after death
Hey it's your car, do want you want to it.
I feel more peak power in the LS between 4500-5500 rpms. The redline is 6800, with hardly any power up top IMO. The B18 has a midrange powerband, and should not be reved that high unless you want to push a piston through a cylinder wall.
Taking that engine past redline from first to second gear is just retarded.
Peak power at 6800 nah, The LS head chokes itself at 6000 rpms.
Old Nov 3, 2004 | 10:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Man I have taught you a lot j/k :db:
Old Nov 3, 2004 | 11:34 AM
carta79's Avatar
carta79
Life after death
Well it seems coincidental that people that are having this sycro problem, are people who are taking their car past redline.
A quick shift at 7000 RPMs is good way to wear the syncros down.
I taught you everthing you know bish. :fawk:
