Timing belt replacement..what the hell?
Old Oct 29, 2004 | 09:50 PM
jweltch's Avatar
jweltch
Closet Ricer
Default Timing belt replacement..what the hell?
Car: 1995 Civic
Engine: D16Z6
I'm replacing the timing belt (among many other parts).
Both manuals I've looked at tell me to remove the power steering pump and both say not to disconnect the lines. Fair enough..
Only problem is that there are metal lines going into the rubber lines. The rubber lines aren't long enough to "move the pump out of the way". I'm also trying to move the reservoir, same problem. There are 2 pairs of metal lines: 1 pair goes toward the front (power steering cooler?), while the other pair go toward the rear (these wrap around the motor mount). I've removed 2 mounting brackets in an effort to make the metal lines easier to move but no dice.
How do you guys do it? Should I just disconnect the lines and bleed the p/s when I'm done?
Old Nov 4, 2004 | 09:01 AM
bnuk's Avatar
bnuk
on my tegra it was fairly tight if you just pop the resivior out of its braket you can kinda slide them both over to right. still somewhat in the way though.
