DAMMIT... my amps overheating again...
that'll happen if you're running the amp say at 1 ohm when its only 2ohm stable. what kind of amp do you have? what is the amps impedance(how many ohms is it stable to?) what is the impedance of the subs and how many of them are you running and how? Are they SVC, DVC, how are they wired?
If its not what 94uhkord said, then try this: Where do you have your amp mounted? Is it getting enough air? Do you have it mounted in a way that the top of the amp is upside down? Do you have your gains turned all the way up?
:dunno:
:dunno:
yeah i tried ventalation and turning the gains down..
but now i want more bass and it heats up faster .. maybe its just the crappy weather .. but this is ridicolous..
as for what 94uhkord said.. i have no clue about the #'s on the amp or the subs cause i got them used.
Hey I'm going to bed now... just ran across this thread again and found what you were looking for, so I will post that up now and try to help you out in the morning...
FEATURES
QX2180 Output Power:
4 ohm Mono 180 x 1
2 ohm Per Ch. 90 x 2
4 ohm Per Ch. 55 x 2
Continuously variable, 12dB per octave,
30 to 600Hz highpass or lowpass crossover with defeat
Dual-color LED indicator for power-on and protection
Adjustable Input Sensitivity Control
Adjustable 0 to 15dB "twin t" 45Hz bass boost
Advanced Overload and Thermal Protection
Muting circuitry for soft turn-on and turn-off
Gold plated high current power and speakers terminals
Gold plated signal input RCA jacks
Dimensions, Chasis 9.13L x 8.50W x 2.00H
Dimensions, Overall 10.13L x 8.50W x 2.10H
FEATURES
4 ohm Mono 180 x 1
