leakage on a manual trans 98 civic hx
I need to know where to fill/check the trans fluid on a manual 98 civic hx. I dont have a manual. Is it the little hollow tube on top with a rubber cap? Als othe reason for the fill is there is trans fluid slowly dripping from where the gear shift linkage enters the tranny. There is a boot but it drips out on the garage floor slowly over a few weeks. I was told there is a seal that can be replaced, so second question is, is it hard to change that seal? Any special tools needed to remove it?
Thanks,
Brian
Thanks,
Brian
My '95 Integra tranny has a vent tube kinda like you're describing. You can probably fill it there(??) but can't check it there.
If yours is the same, the fill/check plug is alongside the right axle. Look in thru the right fender, it's behind the axle, about the same level. It's a different size & looks different than the tranny case closure bolts.
