Is this a good amp??
Old Oct 19, 2004 | 12:36 PM
Zzhatch's Avatar
Zzhatch
Default Is this a good amp??
Kenwood
2-Channel Power Amplifier
Key Features
Maximum Output Power: 600 Watts x 1
Power Ratings
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz,
0.08% THD): 100 Watts x 2
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8%
THD): 150 Watts x 2
Bridged Power Output at 14.4V (1kHz, 0.8% THD):
300 Watts x 1
Power Supply Features
Power MOSFET Switching Power Supply
Copper-Shielded EE Core Transformer
Large Toroidal Noise Suppression Filter
Black Anodized Top Cover: with Aluminum Heat
Sink Plate
Large Secondary Capacitors
Power Indicator
2-Ohm Stable
Audio Features
Stereo, Mono, or Tri-Mode Operation
Selectable Low-Pass Electronic Crossover
Ground Isolation Circuit
RCA Audio Inputs: Gold-Plated
Speaker Level Input Terminals: Screw-Type
Speaker Connectors: Gold-Plated, Screw-Type
Quiet Turn-On
Speaker Relay Protection
Is this a good amp?? I have two audiobahn 12 inch subs that can handle up to 400 watts, is this good enough to power the speakers correctly? or should i look for a better amp?
Also i do not really understand the difference between 2 ohms and 4ohms.
Old Oct 19, 2004 | 07:11 PM
Zzhatch's Avatar
Zzhatch
nobody has any input about this amp?
Old Oct 19, 2004 | 09:03 PM
97teg's Avatar
97teg
what configuration are your subs? are the dual voice coil and what ohms? If its enough will depend on how loud you want to get. I might look at a bit more power though.
Old Oct 20, 2004 | 02:06 PM
Zzhatch's Avatar
Zzhatch
would this sub be better for my mids and highs??
