Brake light on dash
R ENVY
Brake light on dash
I have just bled the brakes on my R and now every time I push the brake the brake light on the dash comes on momentarily. Wonder what the problem could be.
Could be a few things.
If the brake fluid isn't above the fill line in the master cylinder, then the light can come and go as the pressure causes the fluid to rise and fall in relation to the switch attached to the cap's float.
If you weren't careful to tighten the bleed valves correctly, then you could have a minor pressure leak that will trip the brake warning. Check to see if you're leaking brake fluid at the calipers, at the bleed valves or at the seals.
How does the pedal feel? Is it soft or firm the way it should be? Does it slowly sink to the floor? If it slowly sinks to the floor and you cannot find a brake fluid leak at the calipers, it's possible your master cylinder has gone bad.
Unfortunately, what often happens is that when people work on the ITR brakes they will push the pedal to the floor in the bleeding process.
This will push the MC piston beyond where it would normally travel in the MC housing, and this will push it beyond rough places and corrosion in the MC that it would not normally encounter.
This causes shredding of the seal, unfortunately.
If this is what you've done, then an MC replacement is on the horizon. Luckily, they're not ruinously expensive.
Please come back and let us know how this turns out.
Originally Posted by fgfournet
I rebled the brakes, put new pads, and had the rotors turned. Everything is OK now. Thanks.
