4th Gen Accord front wheel shake
Old Oct 8, 2004 | 03:44 PM
Spyfunkr's Avatar
Spyfunkr
Default 4th Gen Accord front wheel shake
I have a constant shake in my front end, gets worse with braking. I know I have loose tie-rod ends, and Ive ordered them. Could this be a wheel bearing issue? Anyone have DIY pics of tearing apart the wheels?
Thanks, Spy
Old Oct 8, 2004 | 04:15 PM
luky1380's Avatar
luky1380
first try tie rod and if still gona have vibration when you push the brakes replace front brake rotors and pads and try ballance your tires
Old Oct 8, 2004 | 04:21 PM
Spyfunkr's Avatar
Spyfunkr
Ive had 4 sets of wheels/tires on the car, load balanced, etc. The shake is there with or without braking.
Thanks, Spy
Old Oct 8, 2004 | 10:25 PM
tjr5150's Avatar
tjr5150
put that side of the car on a jack and lift it up if you can shake your wheel then you need to replace your balljoint i had this problem before and replaced tie rods inner and outer i ended up nickle and dimeing myself to death
Old Oct 8, 2004 | 11:02 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sorry to cut into this thread but how would you determine your wheel bearing is bad?
Old Oct 9, 2004 | 07:44 AM
Spyfunkr's Avatar
Spyfunkr
Good question, in fact, thats part of my question.
Thanks, Spy
Old Oct 9, 2004 | 09:42 AM
luky1380's Avatar
luky1380
wheel bearing not gona make your front shakeing brake rotors and tie rods/ball joint
Old Oct 9, 2004 | 10:33 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Rotors could be warped or uneven brake wear (calipers) if the car just shakes when your brake. Since it does it other times too then it could be a cv boot, or a whole axle.
