Integra Engine problems
Old Oct 3, 2004 | 08:21 AM
the0ne's Avatar
the0ne
Default Integra Engine problems
hey im new here, but i need some help. I have a 94 integra gs-r vtec. I purchased the car over the summer, and havnt had any problems with it untill now. I had it parked at my brothers for about an hour then when i got in it and started it was like it was running on 3 cylinders. So i went back and we changed the plugs, its solved the problem for a day then the problem started again. I changed the wires then, the problem wasnt as bad but it still persisted. So i did the diag test, and it gave me 3 codes. 7 10 22. Being Throttle Position, Intake Air Temp, and Vtec oil switch. Someone told me one thing could be throwing all 3 or something. my brother said its like i have a short somewhere im not sure. Someone help please
Old Oct 3, 2004 | 08:31 AM
BoostedITR41's Avatar
BoostedITR41
check your oil.....TPS could be the problem....disconnect the battery and reset the codes and see if the ECU throws them again
Old Oct 3, 2004 | 08:33 AM
the0ne's Avatar
the0ne
my oil was low when it started happening but soon as it started i put some in it... beause i was burning about a quart and a half ever 3 grand miles
Old Oct 3, 2004 | 08:45 AM
the0ne's Avatar
the0ne
ok i just did as sugessted, i disconected the battery then it only gave me the vtec oil switch code
so i disc, the battery again and start it and the check engine light is one
i turn it off and it gives me only the oil switch again...
could this be the prob?
Old Oct 3, 2004 | 10:51 AM
the0ne's Avatar
the0ne
well i went back down for another try and realized last night i disc my oil pressure sensor to spray wire dry in it connected it back up and now its not throwing any codes but the problem is horrible... like its runnin on 3 cylinders n-a-s-t-y help
Old Oct 4, 2004 | 08:16 AM
olly-civic's Avatar
olly-civic
could be the dizzy, mine did that ages ago and it was summit to do with the ignition modual inside the dizzy.
Old Oct 4, 2004 | 08:21 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
i net it is the TPS
Old Oct 4, 2004 | 08:37 AM
ISP James's Avatar
ISP James
DAMIMRED
im guessing the distributor
Old Oct 4, 2004 | 08:43 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
thats a possibility or the rotor
Old Oct 4, 2004 | 12:22 PM
olly-civic's Avatar
olly-civic
well were taking bet's on the dizzy or the tps lol
