El Guage Panel Instructions for 94 Integra GSR
Old Aug 13, 2002 | 05:20 PM
Zedron's Avatar
Zedron
Turbo B20
Default El Guage Panel Instructions for 94 Integra GSR
I just got the guage panels and they came with no directions.
Does anyone have any directions that may be useful to me?
Old Aug 14, 2002 | 04:27 PM
Zedron's Avatar
Zedron
Turbo B20
Anyone?
Old Aug 16, 2002 | 06:14 AM
GSRacer's Avatar
GSRacer
Shadetree Mechanic
There are 2 screws on the top of the black insert that surrounds your gauges, take them out, then tilt your wheel down and pull firmly on the bottom part of the black thing and it will pop out, there are 2 or 3 screws to get the instrument cluster out, then pop the clear plastic cover off (can be a beast but requires no tools) then there are some phillips screws in the back of the instrument cluster (some are in deep holes) that you must remove to remove the bezel, then just slide yer gauges over the needles, and glue em down, route the wires back behind the cluster and mount your transformer in the right rear of that gaping hole that you now have in your dash, i tapped into the constant (not variable) power lead to my dimmer for power, and mounted the color changer switch in that useless coin tray!
Old Aug 16, 2002 | 11:48 AM
Nelson's Avatar
Nelson
Administrator
That's pretty much it, GSR covered it pretty well, but if you need pictures and even more detailed instructions, try here: Install Gauges
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 17, 2002 | 07:29 AM
Zedron's Avatar
Zedron
Turbo B20
Thnx alot.
I decided to mount the controls in the useless coin tray also.
Chizzy
15
Aug 5, 2005 05:06 PM
jordan88
92+ Civic/EL & Del Sol
8
Aug 17, 2003 03:56 PM
goldenbear
3
Feb 16, 2003 11:32 AM
tim
Accord
11
Aug 30, 2002 06:20 AM
