Problem with RF 500s AMP
Old Aug 18, 2004 | 07:55 PM
carrwash13's Avatar
carrwash13
Default Problem with RF 500s AMP
well my car was broken into and I just installed the replacement cd player that was stolen and now I can't get my amp (rockford fosgate 500s) thats hooked up to my sub-woofer to work. I actually don't know specifically if the amp is not working but the LED on it is not lighting up and the sub and cd player are definitely working so I can only assume that the amp is the problem. Do amps have fuses that can be blown or other things that could likely be causing this? And the amp is definitely recieving power so that is not the problem.
Old Aug 19, 2004 | 02:50 AM
honura's Avatar
honura
Seni
Maybe the Led light is shot.
Old Aug 19, 2004 | 09:24 AM
Nelson's Avatar
Nelson
Administrator
Amps have fuses...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 19, 2004 | 10:42 AM
honura's Avatar
honura
Seni
Originally Posted by MaxBoosT
Amps have fuses...
But he said that the Amp is working fine.
Old Aug 19, 2004 | 04:48 PM
TTT's Avatar
TTT
reading owns you
How do you know the amp has power? Take a digital multimeter and test the voltage getting to the amp through the power wire, and test the remote wire to make sure that is hooked up correctly. Also make sure you have a solid ground, no paint or anything inbetween the metal.
Old Aug 19, 2004 | 05:13 PM
honura's Avatar
honura
Seni
Old Aug 20, 2004 | 07:39 AM
TTT's Avatar
TTT
:eh:
