ABS code 8-2 ???
Old Aug 14, 2004 | 04:10 PM
DC2GSR's Avatar
DC2GSR
Default ABS code 8-2 ???
Recently my ABS light had came on in my 94 gsr, so I pulled the code. There was 8 fast flashes, then a slight pause, then followed by another fast 2. I read it as code 8-2. Upon researching, I found that code 8-2 meant "CPU Comparison." Does anyone have any ideas what this really means????? If so can some give any advice on how to proceed to get this problem fixed??
Old Aug 17, 2004 | 04:16 AM
JimBlake's Avatar
JimBlake
I looked that one up... Apparently there's actually 2 ABS computers together in the same case, & they compare answers. If they don't agree that's not good. If you reset & it keeps coming back you gotta replace the ABS 'computer'.
Old Aug 17, 2004 | 05:39 AM
LT's Avatar
LT
The deer had to die!
yea, i just read that too. wow, i didn't know it compared between 2 CPUs. However, if you do keep resetting it and getting DTC 8-2 - you have to replace the ABS computer.
Old Aug 17, 2004 | 06:06 AM
carta79's Avatar
carta79
Life after death
I thought 8-2 indicates a faulty ABS control unit. Never heard of this "CPU comparison".
Old Aug 17, 2004 | 09:01 AM
JimBlake's Avatar
JimBlake
That's what my Helm book says.
8-2 = CPU comparison
8-4 = IC self-check
They're both for a faulty ABS controller. I don't know why they bother with separate codes when the 'repair' procedure is the same.
