vtec not working
Old Aug 10, 2004 | 06:41 PM
IovetoXLR8's Avatar
IovetoXLR8
Default vtec not working
ok so my check engine light has been on for a whilein my 98 gsr. pulled the codes, said it was running too rich. took it to local shop to see what they thought, got the same answer. they said there is nothing wrong with any of my sensors and whatnot and that i was lucky. he said gas just builds up from a lot of stop and go short driving trips (i deliver for dominos). so he told me every once in a while to run it a little hard and get rid of some of the excess gas. they reset everything for me and everything was cool. i take it to the freeway and im shifting at about 6.5-7k rpms every gear just to run it hard a little and check everything. sure enough, in 3rd gear as soon as i hit vtec (around 5k) the ****in engine bogs out and stops accelerating again and my check engine light is back on. what the ****. i got an oil change not even 2k miles ago but my oil light seems to like going off lately. would that cause the engine to bog out? should i get a leakdown test or something? please any help would be greatly appreciated. thanks.
Old Aug 10, 2004 | 07:15 PM
honura's Avatar
honura
Seni
I don't know but how long has it been since your last tune up?
Old Aug 10, 2004 | 10:28 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
my friends got a crx with the same prob
worse it shuts down/bogs at 4K
when we took the zc aprt it was because he had quite a few valves bent
the CEL was on the whole time even if reset the battery
Old Aug 11, 2004 | 06:35 AM
Daniel's Avatar
Daniel
If your oil light is coming on and VTEC is not engaging, it sounds like an oil delivery problem. Have you checked your oil level lately? Do you see any dark stains on your engine block from a possible gasket or seal leak?
Old Aug 11, 2004 | 08:43 AM
RB's Avatar
RB
snitches get stitches
agreed...
Old Aug 12, 2004 | 03:36 PM
ska32198's Avatar
ska32198
Oil light=Idiot light... If it ever comes on, dont even think about driving your car, I wouldnt be suprised if you didnt do some damage right there
Old Aug 13, 2004 | 12:18 AM
IovetoXLR8's Avatar
IovetoXLR8
yeah...so anyway...
so i put in some oil today and that took care of the vtec problem im thinking maybe i have an oil leak or somethings wrong. can you guys tell me some possible problems it might be? should i get a leak test? i notice NO problems in the cars performance (other than vtec which was fixed by oil) and the shop said no sensors are damaged etc. should i jus get a tune up and have the whole engine checked?
Old Aug 13, 2004 | 11:30 AM
94GsArrr!'s Avatar
94GsArrr!
DOHC VTEC B18C1
when your about to drive your car after its been parked for afew hours just look at the floor to see if theres any oil puddles on the floor. that should help you figure out where its leaking. try to follow the leaking oil.
Old Aug 13, 2004 | 12:30 PM
Kai's Avatar
Kai
Rotorphile.
If you haven't topped off the oil in the last 2k miles since you're last oil change, it probably just burned some off. VTEC won't engage if there is not enough oil in the system to keep the engine well lubed at those high RPMs. Check your oil at every or every other gas stop!
Old Aug 23, 2004 | 08:07 PM
JRSCGSR's Avatar
JRSCGSR
jeremy
all i can say is LOW OIL PRESSURE dont drive it hard till you figure it out or its gonna blow these b18s have weak oil pumps they are known to fail. get a oil pressure guage on that baby
