Torque Steer issue
Old Aug 9, 2004 | 08:47 AM
bart_dood's Avatar
bart_dood
Default Torque Steer issue
I have put a couple of hundred miles on my Teg, and one thing I've noticed is there is a definite tendancy for it to pull to the left under throttle.
I thought as the Teg's have an intermediate bearing type driveshaft setup that they would be immune from this kind of torque steer.
My question is, do all Integras do this? Or is mine (120k miles) in need of new bushes and if so which ones should I check/replace?
Thanks
Chris
Old Aug 9, 2004 | 09:24 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Is it a subtle tug when you're accelerating briskly, or is it a struggle to keep the car going straight? If it's the latter, something is definitely off.
My bet is excess camber, or some other issue with suspension..
Is the car lowered? If so, how far and with what components?
Also, run a search for "torque steer", please. This topic has been covered a number of times.
Thanks. :cheers:
Old Aug 9, 2004 | 10:09 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Check your alignment and motor mounts.
