stereo shuts off while bass is hitting
Old Aug 8, 2004 | 07:57 PM
miguel6632's Avatar
miguel6632
proud 96 sol owner
Default stereo shuts off while bass is hitting
well i heres my system on my 96 del sol
jvc 1300 mp3 cd player
4 6.5" dual speakers
2 1200w sony amps
2 P5's sony 12" subs running mono with each amp
4 1/2" tweeters
the problem is that when the bass hits really hard the stereo goes off and then comes back on even with the car on it has only a 8 gauge wire for the 2 amps , but also it just killed my battery , now it doesnt hold a charge , i guess becouse i kept draining it too often,(deepcycle)
Old Aug 8, 2004 | 08:46 PM
Baget's Avatar
Baget
All Show and No Go!
get a 1 farad cap and that'll fix it
Old Aug 8, 2004 | 10:41 PM
lgbr's Avatar
lgbr
Wal-Mart Shopper
Sounds like you've got too much of a voltage drop. You need a capacitor or you're going to do damage to your alternator, too.
Optima yellow top never hurt neither
Old Aug 9, 2004 | 02:10 AM
saga's Avatar
saga
broke college kid
What everyone else said. Get a capcitor. Optima yellow will also be a nice addition as well.
Old Aug 10, 2004 | 12:48 AM
tegryder23's Avatar
tegryder23
cgp dc4
damage to the alternator is not good
Old Aug 10, 2004 | 06:23 PM
lgbr's Avatar
lgbr
Wal-Mart Shopper
No! Honda alternators can be expensive. Unfortunately I melted my alternator when I tried to put two batteries in the car with a battery isolator.
Old Aug 10, 2004 | 07:19 PM
miguel6632's Avatar
miguel6632
proud 96 sol owner
well after i turn the system off at night after being played for about 20 min, the headlights are really dim, i have to drive like that for about 10 min so they go back to normal, i was thinking my battery died alredy and it's only 3 months old a diehard just in case it makes any diffrence,,, well now im planing on 2 caps since their only like 80 for the digital rockford fosgates ones, with my discout ,
whats the diffrence between the yellow top and the red, etc batteries????
Old Aug 12, 2004 | 02:05 PM
rcurley55's Avatar
rcurley55
STEP 1 - upgrade the power wire - 8 ga is FAR too small for this kind of application - you are already getting a large voltage drop at your amplifier. It may be dropping below 11v at the amp, causing them to go into protection - this is on top of your alternator problem.
A simple 1F cap won't fix this. Install the amplifers properly, then assess the charging system.
Old Aug 12, 2004 | 04:20 PM
honura's Avatar
honura
Seni
True True True.
Besides having cheap amps, 8g wires are way toooooo small. You should get a 2-3 farid cap and a yellow optima batt. I had my system hooked up to my stock setup and I drained the crap out of my batt. I changed everything using 2g then 4g split, 3 farid, yellow optima, Bam Shit is straight.
Old Aug 12, 2004 | 07:44 PM
miguel6632's Avatar
miguel6632
proud 96 sol owner
Originally Posted by honura
True True True.
where can i get a 3 frad cap???? never heard of those i know about the 1 frad one, well i was thinking of installing a one frad on each ,dont u think that should be enough, well i was playing with it the other day and i touched the 8 gauge wire and man it was preety hot
