timing belt probelm
Old Jul 22, 2004 | 10:45 PM
v t e c dc2's Avatar
v t e c dc2
WHAT iT DOO
Default timing belt probelm
okay today i was putting in some cams in my 94 ls and the timing belt is loose on the side close to the firewall its like the tensioner isn't tighting that side even tho i tighten the bolt, the top and front side tightens up but that side i can push out a bit which is causing it to skip anyone had this probelm before? tryed searching but don't see anything..help me out
Old Jul 23, 2004 | 06:22 AM
JimBlake's Avatar
JimBlake
You know you don't tighten the belt by simply tightening the tensioner bolt, right??
Old Jul 23, 2004 | 06:27 AM
rgbpmp's Avatar
rgbpmp
search.
its been covered here.
Old Jul 23, 2004 | 09:14 AM
v t e c dc2
WHAT iT DOO
seen that, which doesn't help...
Old Jul 23, 2004 | 09:41 AM
pirate252's Avatar
pirate252
Originally Posted by rgbpmp
As shown in the helms manual.
1. Loosen the adjusting bolt 1/2 turn
2. Rotate the crankshaft counterclockwise 3 teech on the camshaft pulley.
3. Tighten the adjusting bolt.
If that doesnt work then i would say your tentioner is broken
Old Jul 23, 2004 | 10:05 AM
v t e c dc2
WHAT iT DOO
do they only sell the tensioner pulley in kits?
Old Jul 23, 2004 | 10:10 AM
rgbpmp's Avatar
rgbpmp
you can get the tensioner at autozone or at the dealer. Im sure most autoparts stores have them.
Old Jul 24, 2004 | 12:45 PM
pirate252's Avatar
pirate252
Yes
