ABS bleeding on 98+ teg????
Anyone has instruction on how to bleed the ABS in 98+ integra? My 99GS ABS system does not look like it has a resevior or a bleeding nipple at all. I have a strange noise at cold start ups that lasts about 30-40 seconds. There was a recent post that air in the ABS system can cause the strange noise. The strange thing is that when I pulled the ABS pump fuse, I still get the buzzing noise....Help!!!!!!!!!
Or get a Helm repair book for your car. It'll say exactly what to do...
I'm only guessing here, but maybe it's about the same as my '98 Accord. That one bleeds right thru the ABS unit when you bleed the main brakes. So you don't need to do the ABS separately. The only difference is which order you do the wheels.
yeah on my car you have to have the engine running, and go in this order, driver side front, passenger front, driver side rear, passenger rear, which is pretty much reverse of standard order.
DB Squad
Integra Forum Moderator
DB Squad
