what kind of fuel line i need for skunk 2 im install
Old Jul 19, 2004 | 11:07 PM
greengsr2k's Avatar
greengsr2k
Default what kind of fuel line i need for skunk 2 im install
hey guys,my friend just installed skunk2 im on my gsr,i got the ls fuel line but it started leaking gas.I got the ls fuel line from junkyard.What type of fuel line do you guys recommend ,so it wont leak gas,i was shock .im still waiting for itr throttle body,my gsr throttle is messin my idle up ,it gets stuck.
Old Jul 19, 2004 | 11:17 PM
LT's Avatar
LT
The deer had to die!
you can find almost any length fuel hose at automotive stores. 3/8's btw.
Old Jul 20, 2004 | 05:29 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I don't know why you're having so many problems with this mod (seems to be a trend... *cough* struts *cough*), but my Skunk2 installed flawlessly. I use a GSR fuel line that runs from the filter to the fuel rail. Remember to use Teflon tape on fuel fittings so they won't leak. Also, why would your GSR TB cause problems with your idle? I use a GSR TB on my Skunk2 manifold and I have no problems... seems to me that you may have a problem with the TB gasket. Did you put a new one on there?
DIY: http://www.ff-squad.com/tech/howto/sk2manifold/
Old Jul 20, 2004 | 06:32 AM
greengsr2k's Avatar
greengsr2k
i put the copper washer s on the wrong place,it was top but suppose to be on bottom,how did you use gsr fuel line its short,it hits the top of the intake,i am no problem with gsr tb,just throttle cable and pulley is angled,and the idle gets stuck,so thats why i got the itr tb
Old Jul 20, 2004 | 01:14 PM
westcoaststyle
I'll see about taking a pic tonight.
Are you talking fuel line from the filter to the rail or return line from the FPR to the hardline?
If you use the GSR TB with a civic or B16A or B18A/B throttle cable pulley and ITR throttle cable bracket that bolts to the IM, you will be fine. If you look at the DIY I posted above you will see what I'm talking about. They outline these parts.
