idle stuck after skunk 2 im install
Old Jul 15, 2004 | 08:06 PM
greengsr2k's Avatar
greengsr2k
Default idle stuck after skunk 2 im install
i have a problem guys,i used the gsr cable and bracket and pulley and now my idle gets stuck at 2 or 3.When i let go of gas the idle stays at 3 or 2,even at full stop.I bought a itr throttle body so it will fix the problem,just waiting for it to be ship to me.Is the itr tb worth it.Will i notice any gains.
Its very annoying each time i let go of gas it stays at 2 or 3 idle until i press the clutch and place in gear, the idle goes down.How do i fix the problems guys, please help me.
Im using a hondata intake manifold gasket which is thicker.
Old Jul 17, 2004 | 09:53 PM
greengsr2k's Avatar
greengsr2k
please help me moderators
Old Jul 18, 2004 | 04:23 AM
Kai's Avatar
Kai
Rotorphile.
Sounds like a vacuum leak to me. Did you use a new throttle body gasket?
Maybe the throttle cable is too tight, or is catching on something. Check it for proper slack.
Old Jul 18, 2004 | 07:23 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Follow this: http://www.ff-squad.com/tech/howto/sk2manifold/
I agree that it could be the cable being too tight. If you get an ITR TB you will need the ITR cable and intake manifold bracket for the cable.
hih
Old Jul 18, 2004 | 11:12 AM
v-teg01's Avatar
v-teg01
Candy
i had a similar problem when i got my skunk2 im but my idle was surging and a couple times sticking. I beileve itsyour tps voltage on the back of the tb, im sure it needs to get tuned. Well in my case i got a Jg tb right away and it basically fixed the problem. As for the gains of your ITR tb it's 65 mm right well that the same as my JG, the gains i felt were lots of extra throttle response, is a fun mod.
:edit: If u get your itr trottle body u will need th ITR cable bracket too, this make the cable run horizontal, in stead of at an angle like the GSR's
Old Jul 18, 2004 | 02:44 PM
SWOOSHER21's Avatar
SWOOSHER21
Fight Rice
check the right side of the manifold. there is a hole that needs to be plugged. some dbag i work just put a skunk2 manifold on his d series and he forgot to put this piece in the hole and the car would just rev between 2k and 3k rpms. you may just want to check that out to see if thats the problem.
Old Jul 18, 2004 | 03:09 PM
greengsr2k's Avatar
greengsr2k
itsa not a vacuum leak,i believe the throttle gets stuck because it touches the hood,im still waiting for my itr throttle body so it will fix all the problems
