Axle problem
Old Jul 7, 2004 | 10:25 PM
steven zipkin's Avatar
steven zipkin
Default Axle problem
My 2001 type r keeps eating the driverside cv axle. I replaced it 3 times and it goes bad after about 400 miles. Anyone know what might be wrong? Drives great after the new axle is installed but then goes bad and the whole car shakes.all the motor mounts look good i think and the balljoints and wheel bearings seem fine too.Its been doing this since i hit a pothole months ago.Its the outer part of the shaft that goes into the wheel that goes bad.
Old Jul 7, 2004 | 10:51 PM
Nelson's Avatar
Nelson
Administrator
How is the lower arm?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jul 12, 2004 | 08:34 AM
steven zipkin
The lower arm looks fine do you think it might be a wheel bearing since it keeps going bad.
Old Jul 12, 2004 | 06:19 PM
sensei's Avatar
sensei
the wheel bearing could be causing it, but it is more likely a geometry problem caused by your pothole incident...check all bushings in the arm, the shock, shock mount, alignment, and double check all engine mounts.
Old Jul 12, 2004 | 06:31 PM
FA9S8U's Avatar
FA9S8U
The shaking sounds more like a tie rod, more then anything....if it was the bearings, its usually more of a whiring noise you hear like from a big [...] truck
Last edited by George Knighton; Jul 13, 2004 at 04:42 AM. Reason: Removed pejorative class identifier.
Old Jul 14, 2004 | 08:32 PM
steven zipkin
I think its a motor mount, will the poly inserts fix these.
Old Jul 15, 2004 | 03:42 PM
FA9S8U's Avatar
FA9S8U
I still say check your tie rod it's a piece of cake to change and most likely what broke when you hit a pot hole!
Old Jul 15, 2004 | 09:18 PM
steven zipkin
the motor mounts were bad thanks
Old Jul 16, 2004 | 01:35 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
well at least you got the thing fixed
Old Jul 16, 2004 | 05:05 AM
George Knighton's Avatar
George Knighton
Surprised to hear that. My car has over 80,000 hard miles on it. Motor mounts still fine.
Glad you got it fixed, anyway.
