Re: throwing a code....cant find where to jump it.
Originally posted by crucial Si i have a 92 si and i cant see where i need to jump it to see what code i am throwing. any help please, thanks
Try www.jdmfan.com. There is a whole section about checking the code by using a paperclip, watching the blinks, and then a chart will tell you the code by how many long/short blinks you saw.
Originally posted by crucial Si yeah but i dont know where to jump it using the paperclip.
just go read it...there is some sort of green harness i think and you make a U out of the paperclip and stick one end in the one of the clip holes and the other end in another clip hole....at least that's what i remember. it will tell you how to do everything
Originally posted by crucial Si yeah i found it..was way up there..anyhow
code 22...
22 VTEC Oil Pressure Switch Open or short in VTEC OPS circuit, defective VTEC pressure switch
WTF does this mean and what do i need to do?
hrmm...if it was the defective vtec pressure switch i would guess your vtec solenoid is having problems and isn't engaging when you hit the proper rpms. As for the first one i have no idea...call the dealership up.
