Audio, Security, & Automotive LightingTroubleshoot wiring problems and get equipment suggestions all in one place. Now expanded to include Automotive Lighting
i wouldn't reccomend it, those amps usually aren't made for running subs. they usually only put out 75-150 watts per channel. personally i would get separate amps for each...
ok, it sounds like it may work, but realistically those subs can handle alot more power than the amp is going to give them. if they RMS at 400, and the amp maxes out around 500, they can take alot more. drop them all down to 2ohms and wire one to a channel. even then they'll be underpowered.
get a wiring kit that is good up to like 1,000watts. that way when you wanna upgrade in the future you won't have to worry about wiring your car up again. you need power wire from batt. (probobly like 4guage) and ground to match, rca's from the headunit for each channel you're running a sub off, and the remote wire to turn on the amp. oh yeah, and speakerwire for each sub from each channel.
brands don't matter too much when it comes to power & ground, if you're having noise issues go w/a good set of rca's like monster cable or something. goodluck!
