Sub/Amp question.
Old Jun 15, 2004 | 12:45 PM
93DelSolSi's Avatar
93DelSolSi
Default Sub/Amp question.
Ok to start off i know very little about amps.
My question today is, if i have 3 subs in my car, can i use a 4 channel amp ?
Thanks!
Old Jun 15, 2004 | 12:50 PM
SOHKeg's Avatar
SOHKeg
i wouldn't reccomend it, those amps usually aren't made for running subs. they usually only put out 75-150 watts per channel. personally i would get separate amps for each...
Old Jun 15, 2004 | 12:53 PM
93DelSolSi's Avatar
93DelSolSi
Boss "Chaos" 2000 Watt 4-Channel Amplifier
200 Watts x 4 @ 4 OHMS Stereo
500 Watts x 4 @ 2 OHMS Stereo
1000 Watts x 2 Bridged
12" Audiobahn Subs Subwoofers AW1251T
They have a RMS of 400 watts, and a Max of 800 watts. They are Dual voice coil, and a 4OHM.
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Will this work ? if not what will i need ?
Old Jun 15, 2004 | 01:05 PM
SOHKeg's Avatar
SOHKeg
ok, it sounds like it may work, but realistically those subs can handle alot more power than the amp is going to give them. if they RMS at 400, and the amp maxes out around 500, they can take alot more. drop them all down to 2ohms and wire one to a channel. even then they'll be underpowered.
Old Jun 15, 2004 | 01:08 PM
93DelSolSi's Avatar
93DelSolSi
so i can use that one 4 channel amp ? then get a amp wire kit ? then im set ?
what amping wiring kit do i need ?
Old Jun 15, 2004 | 01:43 PM
SOHKeg's Avatar
SOHKeg
get a wiring kit that is good up to like 1,000watts. that way when you wanna upgrade in the future you won't have to worry about wiring your car up again. you need power wire from batt. (probobly like 4guage) and ground to match, rca's from the headunit for each channel you're running a sub off, and the remote wire to turn on the amp. oh yeah, and speakerwire for each sub from each channel.
Old Jun 15, 2004 | 01:58 PM
93DelSolSi's Avatar
93DelSolSi
can you list the brands and the names of the stuff that i would need ?
Links ?
Pictures would be cool.
thanks again!!!
Old Jun 15, 2004 | 02:01 PM
93DelSolSi's Avatar
93DelSolSi
and that 4 channel amp will work with the 3 subs right ? Thanks Again!!!
Old Jun 15, 2004 | 02:07 PM
SOHKeg's Avatar
SOHKeg
brands don't matter too much when it comes to power & ground, if you're having noise issues go w/a good set of rca's like monster cable or something. goodluck!
Old Jun 15, 2004 | 04:40 PM
93DelSolSi's Avatar
93DelSolSi
well can u list what i need,
just subs, amp and the wiring kit ?
