Going To Be Pushing Over 1200 RMS
Old Aug 7, 2002 | 06:25 PM
A96's Avatar
A96
Default Going To Be Pushing Over 1200 RMS
should i, buy a high output alternator, or will a capacitor be just fine?
Old Aug 7, 2002 | 06:27 PM
b00gers's Avatar
b00gers
with what amp? if its a pyramid amp, no. =P
a real amp...we would need to know what car you have.
Old Aug 7, 2002 | 10:20 PM
A96's Avatar
A96
it'll be a crossfire vr1202, and it's an accord.
Old Aug 7, 2002 | 10:34 PM
b00gers's Avatar
b00gers
this is MY OPINION.
if that is it for your system, i would just get a 1 farad cap and forget the new alternator.
if you are planning on getting another amp, such as a 4ch amp, i would definitly get a stronger alternator.
but in both cases, if you have the money, get a stronger alternator.
Old Aug 8, 2002 | 02:47 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
i would suggest a rebuilt alternator for high current amps. How many amps does the amp draw? how much amerage doed the alternator put out? if ur alt puts out about 60 amps and your amp needs 90... time for a rebuild!
rebuilt alts should cost about 150, and is much more effective. However, increasing the amperage output tends to make you lose HP.
one more thing, is that amp a class d amp?
Old Aug 8, 2002 | 07:45 AM
A96's Avatar
A96
my amp is a class A/B.
my stock alt, puts out 90 AMP>
The amp will draw about 170 AMP>
Old Aug 8, 2002 | 07:58 AM
SiClone's Avatar
SiClone
X-Moder8er
Holy crap!! That's some major draw there. I'm thinking that's maximum draw though. What I would do is hook everything up first, see if you have a major dimming problem, and then work on a solution.
A re-wound alternator would be nice, but does cost more...
Old Aug 8, 2002 | 10:48 AM
b00gers's Avatar
b00gers
that amp is HUGE. you will have to invest to a stronger alternator.
Old Aug 9, 2002 | 05:37 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Good god....170amps of current??
I would definately get your alternator rewound for higher output.
Old Aug 10, 2002 | 12:27 AM
A96's Avatar
A96
well, i found a local place that can hook me up with a 175AMP alt. They will install, and upgrade all the necessary wires. Include, a 6 month warranty.
Including taxes and everything, should come out to.....
$950!!!!!
i think i might do it in sept.h:
