Turbo EX or JDM B16???
Old Aug 6, 2002 | 09:35 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
Default Turbo EX or JDM B16???
okay...i've heard way too many different conflicting things about motor swaps and turbos. what i would like is a daily drivable car that's quick and relatively reliable. also, i'd like to spend around $4k-$5k total this time around. A bunch of people tell me to just get a new motor, but my mechanic tells me to just put a turbo on my car and turn up the boost. then i did some research, and found that a turbo ex is not much faster than a stock si (unless the motor is fully built). he also said that if i swap the motor it could be a problem for emissions(vins dont match) and that i could run higher boost on my sohc than a dohc. any thoughts???
Old Aug 6, 2002 | 09:36 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
Turbo ur engine now
Old Aug 6, 2002 | 09:37 PM
Smurf's Avatar
Smurf
yes smog check will own u when they look at it.
Old Aug 6, 2002 | 09:43 PM
yellow civic ex
another thing tha tmy mechnic said that got my attention is that if i drive conservitavely then i'd keep just about the same fuel economy that i have now....true???
Old Aug 6, 2002 | 09:44 PM
Smurf's Avatar
Smurf
With turbo or swap, you will lose some, less with the turbo i belive.
Old Aug 6, 2002 | 09:54 PM
yellow civic ex
Default boost
if i put a turbo on tho, the most boost i could safely put on an ex motor is like...6 or 7 lbs...i'd prolly want to at least replace the gaskets/bearings/pistons
i have 75k miles on it
if i boost i'd wanna get the turbotimer, boost controller, intercooler, and a nice bov...with the boost controller i'd probably be tempted to turn the boost way up, so i'd wanna be sure i could take it
Old Aug 6, 2002 | 10:10 PM
Smurf's Avatar
Smurf
k then, now - DO IT
Old Aug 6, 2002 | 10:28 PM
underboost's Avatar
underboost
boost yummy
Old Aug 6, 2002 | 10:37 PM
yellow civic ex
is there anyone out there that has any regrets about going one way or the other?? just wanna know before i spend so much time+money
Old Aug 6, 2002 | 11:33 PM
ManTiS's Avatar
ManTiS
NinJA
This is an ongoing argument: turbo or swap? I like turbos so I am biased. I stuck with the SOHC for bragging rights. If I swapped in a motor LEGALLY, then it'd cost me at least $3000 for a B16a and even more for a B18c1. Remember I have a 2000 EX.
Quit asking 'virtual' people and ask yourself: "Do I want a better foundation for modifications, or do I want to have a quick SOHC?" My SOHC is tight, I like it. Sooooooo many of my friends said I should have swapped, but wait until I hit the track.
