sub thumping problem sony x-plod deck concept amp 2 12'' mtx subs
Old Apr 26, 2004 | 05:49 PM
98accordpimp's Avatar
98accordpimp
play it loud
Default sub thumping problem sony x-plod deck concept amp 2 12'' mtx subs
i had my system installed by a pro and every time i pop a cd in or skip a track my subs make a thumping sound. Anybody have any ideas on whats causing the pob???
Old Apr 26, 2004 | 07:48 PM
flyromeo3's Avatar
flyromeo3
Check the ground on your radio. Make sure its in FULL CONTACT with metal.
Scrap some paint off if you have to.
Also might wanna check the sub ground as well.
Old Apr 26, 2004 | 08:35 PM
IamNemo's Avatar
IamNemo
You know me...
This belongs in a different forum...specifically Audio & Security under Tech Forums.
As far as what Romeo said, he has a good idea on where to start.
Old Apr 26, 2004 | 09:02 PM
5thgenAccordEX's Avatar
5thgenAccordEX
The Italian
yep check your grounds, 80% of the time they are the cause of most problems
Old Apr 26, 2004 | 09:16 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
could also be that ur amp doesn't have an "anti-thump" circuit either, I've never heard of a Concept amp.
Old Apr 28, 2004 | 05:11 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
It has to do with the remote on the amp.
If you wire up a relay from the remote,.. it'll gave the amp time to shut off/on when you turn your head unit off/on.
Rewire everything first and make sure your grounds are in tact.
Old Apr 29, 2004 | 01:41 PM
98accordpimp
play it loud
Thanx man
Old Apr 29, 2004 | 01:42 PM
98accordpimp
play it loud
thanx but i still need more info
Old May 14, 2004 | 08:21 PM
wing_zero's Avatar
wing_zero
first what is the sampling of your head unit? also are you sure it only makes thumps when you skip a track or etc? may be it does all the time but you don't hear it unless its quiet. or may be your subs or amp is damaged. trying playing something quiet with bass a listen for it.
once i tried to bridge a unbridgible amp, of course the amp was pos or i wouldn't of tried, but anyways yah it messed up the amp. the amp still turned on and everything it just made squeals and weerid sounds fromt he sub, which i never realized until i had a quiet song playing.
if you checked all your wiring and all your equipment, try swapping amps with a friend and see if it still does. as far as i know i wouldn't get a sony amp. sony has some good sound products but i wouldn't say amplifiers are one of them.
if it still does there could be somethign wrong with your head unit
Cosmo M3
May 9, 2004 04:16 PM
firefly
Jan 21, 2004 11:35 AM
hattrickptrck22
Jul 26, 2003 02:29 PM
RaceACCORDingly
Jun 17, 2003 08:09 PM
NSBTypeS
Oct 19, 2002 08:25 PM
