Type R Flywheel On?
Old Apr 25, 2004 | 05:06 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default Type R Flywheel On?
Can a Type R Flywheel fit on a B18B engine?
Old Apr 25, 2004 | 06:05 PM
Madtekniques's Avatar
Madtekniques
cryoteknical
Yes, you will want to get it resurfaced though. It is about 3 lbs lighter I believe, I was going to put one in when I replaced my clutch but the seller didn't get it off his car in time .
Old Apr 25, 2004 | 10:54 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yup, all B-series flywheels are interchangeable. The only parts which are not interchangeable are clutches--all '92-up B-series use one type of clutch while '88-'91 use another.
If you can get the ITR flywheel for a really good price then I'd say go ahead with it, but otherwise you can get an ACT Xact Streetlite flywheel that weighs 12.5 lbs (I believe ITR is 14 lbs) for $225. That's light enough to be noticeable but not so much that it really becomes a chore to drive.
Old Apr 26, 2004 | 09:24 AM
The G2 Racer
Want Boost!
Thanks for the info.
What's a semi cheap clutch that can put up with the power seen from 8lbs of boost?
ITRinEJ1
Jul 10, 2004 11:58 AM
Quick Silver
Feb 3, 2003 01:10 PM
DeviateRacing
Nov 22, 2002 10:53 AM
jdmcrx22
Engine Swaps, Tech & Tuning
12
Oct 11, 2002 08:38 AM
jdmcrx22
14
Oct 11, 2002 03:57 AM
