Spoiler question
Old Apr 25, 2004 | 04:14 PM
integraguy2001's Avatar
integraguy2001
Default Spoiler question
I installed a 3 piece Spoiler, which make my trunk unable to hold itself up when i open it (really heavy), I don't know what you call that thing that holds it up...
Does anyone know where can i buy ones that's can hold more weight? so i don't have to keep on holding the trunk door when i putting stuff in?
Is it easy to install?
thanks,
Old Apr 25, 2004 | 04:33 PM
ISP James's Avatar
ISP James
DAMIMRED
yours might just be shot... so id try just changin them first, get some used ones if you can find em in good shape.... i have a set from a 92 that are still tight.... check and see if they will fit your car, i will send em your way cheap.
Old Apr 25, 2004 | 05:25 PM
integraguy2001
I think the stock one just won't hold, i need something that can handle more weight because my spoiler is really heavy... but thx for offering.
Old Apr 25, 2004 | 06:04 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
I call them Actuators (ak-chu-wators)...but I'm not sure if that's the correct termonology...but yeah, they're fairly simple to install...just a matter of a few bolts.
Old Apr 25, 2004 | 08:36 PM
So.Cal_INTEGRA's Avatar
So.Cal_INTEGRA
Actuators are electric powered. Its the shock right? Should be one on each side, black in Color.
I dont think its the wing, because I have that wing too. I think one or even both are just shot
Old Apr 25, 2004 | 10:30 PM
timmy8151's Avatar
timmy8151
I believe they are known as "trunk stays" If your car didn't come with a spoiler (LS/RS) then the trunk stays aren't designed to handle spoilers. When I put an OEM spoiler on my LS, I had to switch to GS/GSR stays which were designed for spoilers. You can get stays at the dealer for about $50/side or you can buy aftermarket stays at most auto stores. Just make sure to get the ones for models that came with spoilers.
Old Apr 26, 2004 | 05:04 AM
teg128's Avatar
teg128
Banned
lift supports...
you can try this $9 bracket http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
Old Apr 26, 2004 | 06:31 AM
integraguy2001
Originally Posted by teg128
lift supports...
that is what i might go for, but does it fit Integras? Thanks.
Old Apr 26, 2004 | 08:25 AM
pomansouth's Avatar
pomansouth
vice grips are cheaper, just clamp em on and no worries.
Old Apr 26, 2004 | 09:36 AM
integraguy2001
Where can i buy it? can u plz provide a link?
