My Falkens R Rubbin
I was trying to see how wide i could go on my 2k GS. My tires started to ball so i went from my Falkens 512's 205/45 17 to the ones i have now which are the same series 512's but uped the width to 225/45 17 and now i rub on the rear fender, in corners everytime i get more than 2 people in my car. So i would assume that never get anything more than 215's unless your going to mod your fender out. The good thing is my tires are almost worn again. So i can finally fix this dam problem.
I found out the best way to try to get rid off rubbing is to roll up your rear fender lip ... you may ask how ? what you want to do is too lift your car up with a jack and take a wooden baseball bat or and aluminum one and slightly lower the jack while the bat is under the wheel well just enough so you can roll the bat the inner fender lip will roll up with out causing your paint to chip or crack also you wont ruin you inner fender by trying to cut it . next time on bigger wheel applications u never want to exceed a 205/40R17 " tire on smaller compacts. the bigger the wheel the smaller you want to keep your sidewall size. hope this helps.
FunctionMotoring
CRX & Pre 92 Civic
4
Apr 14, 2004 02:45 PM
FunctionMotoring
92+ Civic/EL & Del Sol
Apr 12, 2004 02:07 PM
jdmsoarer
Mar 24, 2004 04:44 PM
pinoydon2003
Jul 17, 2003 09:33 PM
