nitrous ????????
Old Apr 20, 2004 | 02:45 PM
98teggs's Avatar
98teggs
Default nitrous ????????
im looking into buying an entry level nitrous kit i was looking at one that included:
System comes with:
1.4 lb. bottle
solenoid
fill fitting
polyline
jets (biggest is around 50 HP)
arm switch
throttle switch
pushbutton
what else would i need to make this kit complete
not silly gadgets like a bottle opener but gagues etc...
thanks
Old Apr 20, 2004 | 03:24 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Definitely a nitrous pressure gauge, and an A/F ratio meter, IMO. Also, make sure this kit has some provision for a purge line; you'll need to clear your supply line of gaseous nitrous prior to using it.
What brand and type of kit are you planning on buying?
EDIT: A 1.4 lb bottle? Is it a "Sneaky Pete" kit? h:
Old Apr 20, 2004 | 04:29 PM
98teggs's Avatar
98teggs
the nx incognetio kit
i have a a/f gague
Old Apr 21, 2004 | 07:10 AM
TheOtherDave™
Apathy Kills
i have a a/f gague
:rick: Clever. I likes.
I'd also invest in a more robust fuel pump, come to think of it. You'll want to take every precaution to avoid a lean-run condition while spraying. I also assume you'll run a rather conservative jet size (about 50hp).
Old Apr 21, 2004 | 07:27 AM
98teggs's Avatar
98teggs
yeah a 50 jet
i have a holley 192 pump is tis ok or should i go to the 255?
Old Apr 21, 2004 | 01:28 PM
TheOtherDave™
Apathy Kills
yeah a 50 jet
You know, I honestly don't remember what the stock flow rate is...
I'll have to defer to someone else... I'd go for the 255 [liter per hour] pump simply for the extra headroom, but seek confirmation from another source, I'm not entirely confident in my suggestion, and I don't want to make the wrong call. h:
Gentlemen..?
oc_civic
92+ Civic/EL & Del Sol
10
Jan 1, 2006 02:51 AM
pdr
Apr 20, 2004 07:55 PM
drdavidge
Jul 8, 2002 03:22 PM
