metallic buzzing noise when start up /99 integra gs
Old Apr 20, 2004 | 08:11 AM
jliu's Avatar
jliu
Default metallic buzzing noise when start up /99 integra gs
I am new to the acura scene. I just purchased a 99 gs with only 18,000 miles on the car. I discovered when I start the car when the engine is cold, there is a metallic buzzing noise coming from I think on the right side of the engine. It only last the most about 10-15 secs. and it goes away. At first, I thought it was the heat shield, but the shield was found to be tight. I am at a lost. All functions on the car are normal. Is this normal for an Integra????
Old Apr 21, 2004 | 05:56 AM
AXiS's Avatar
AXiS
That's your ABS system pressurizing. It's normal unless it is doing it very often or your brakes aren't working correctly. If that were the case, though, you should have a check light on.
Old Apr 21, 2004 | 06:12 AM
LT's Avatar
LT
The deer had to die!
i don't know of the ABS system pressurizing for 10-15 seconds. Check the lower header bracket. its black and bolts from a tab on the collector to the block of the motor. mine was broken in half and the two pieces vibrated against each other. just a suggestion.
Old Apr 21, 2004 | 08:48 AM
jliu's Avatar
jliu
I searched the forum about the possibility of the ABS pressurizing. My problem is that the ABS light doesn't come on and my GS being a 99' does not have a resevior or at least I don't know where it is. The noise lasts about 25 seconds. I guess I will have to get a repair manual to see how the ABS modual is constructed in my 99GS.
I will also take a look at my lower heatshield to see if it is loose. I doubt it because if it is the heat shield, wouldn't the buzzing noise be happening all the time? Thanks for the help
Jeff
Tobra
6
Apr 25, 2003 11:34 AM
scotthaw
4
Dec 3, 2002 07:53 AM
NYSparky
11
Nov 16, 2002 03:48 PM
95WhiteAcura
13
Oct 10, 2002 07:43 AM
m0nt0
Engine Swaps, Tech & Tuning
2
Aug 28, 2002 12:16 PM
