ITR Pistons/Rods
Old Apr 19, 2004 | 06:37 PM
integraguy_3's Avatar
integraguy_3
teAm coNcepTs
Default ITR Pistons/Rods
thinking about buying some integra type r pistons and rods for my stock Ls. would this be a good idea? will it fit fine? will i have to change other parts when i get them installed? what will they do for me in the performance part? please help me out on this before buying them. your suggestions are welcome. thanks
Old Apr 19, 2004 | 07:31 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The rods will not work, they're not the same length.
The ITR pistons will raise your compression ratio from 9.2:1 to 10.3:1.
Changing pistons is not a simple task, you have to essentially take the motor all the way apart.
Unless you've totally worked over everything else, I would hold off on pistons.
Old Apr 19, 2004 | 07:33 PM
integraguy_3
teAm coNcepTs
thanks for ur help ill wait on all that then thanks again
Old Apr 20, 2004 | 01:56 AM
Kai's Avatar
Kai
Rotorphile.
In case you do it in the future, don't forget that 10.3:1 should be run with high octane "premium" gas. That's an extra 20 cents a gallon (VA prices) every time you fill up.
Old Apr 20, 2004 | 07:50 AM
integraguy_3
teAm coNcepTs
thanks man ill remember that
Old Apr 20, 2004 | 08:05 AM
ISP James's Avatar
ISP James
DAMIMRED
20 cents a gallon x 13 gallons is only an extra 2.60..... and thats assuming you run your car all the way to empty....
Old Apr 20, 2004 | 12:29 PM
Kai's Avatar
Kai
Rotorphile.
Well, for me, thats 20 cents x ~two tanks a week x 52 weeks in a year = around $270 a year extra in gas. It's not that bad, but it does add up in the long run, plus if you only have $5 for gas it won't get you quite as far anymore. It's a big deal for some people, others don't care. :dunno:
egjoe
Nov 19, 2004 10:11 AM
ITRinEJ1
Jul 10, 2004 11:58 AM
PDiggityDogg
Do It Yourself
Apr 4, 2004 06:13 PM
egjoe
Mar 28, 2004 08:57 PM
uoboarder
Nov 23, 2003 11:36 PM
