better handling?
Old Apr 19, 2004 | 04:50 PM
joebenz's Avatar
joebenz
nelson rules
Default better handling?
i have 99 gsr. my current suspension setup is:
Type R Front upper strut bar
Ground Controls
Tokico blues
Tanabe Sustec rear lower arm bar
what would you recommend next to do to make the car handle better? ie.. less understeer.
Or what would have the most impact?
rear sway bar, rear upper strut bar, j's racing pillar bar? any of these? or something diff? i'd just like to get some opinions. THank you.
no sig
Old Apr 19, 2004 | 04:54 PM
LT's Avatar
LT
The deer had to die!
a rear sway bar will greatly change the handling characteristics of your Integra. I have the Comptech rear sway/tie-bar installed on my teg and love it. I can kick the back end out around corners.
rear upper strut bar will do very little, its mostly for show. the c-pillar bar MAY make a difference as that is a thin part of the chassis.
what spring rates do you have?
Old Apr 19, 2004 | 05:01 PM
b00gers's Avatar
b00gers
i would say a thicker rear sway bar also. but what might really help in getting the most out of your car is actually knowing its limits. go to a couple autox competitions or take a driving class that uses your car. :dunno:
Old Apr 19, 2004 | 05:05 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I also have a comptech tie and sway bar, and it's worth every penny. Be careful though... that thing can make throttle-off oversteer a little dangerous, until you're used to it
Old Apr 19, 2004 | 05:28 PM
Tobra's Avatar
Tobra
Driving course would be good, car already handles well, best to learn to get most out of what you already have
Old Apr 19, 2004 | 06:21 PM
reno96teg's Avatar
rear sway bar! it's cheap, and very effective.
Old Apr 19, 2004 | 07:46 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Well, with no actual change of parts you can have a good alignment done and get the corner weights set.
Actual stuff I would add: Neuspeed/Koni SP3 shocks, SPC camber kits front and rear, Comptech rear sway/tie bar combo, Prothane "total" poly bushing kit + rear trailing arm bushings.
b12uceHuy
Do It Yourself
6
Sep 15, 2005 02:06 PM
chimchim
Jan 6, 2004 06:36 PM
DC Sports
92+ Civic/EL & Del Sol
Dec 11, 2003 12:39 PM
shawnmcw
38
Sep 23, 2003 08:39 AM
likaciv
5
Jul 11, 2002 08:53 PM
