shooping for tires
Old Apr 19, 2004 | 03:29 PM
IntegraR's Avatar
IntegraR
Default shoping for tires
hey y'all I have been looking for tires all day long and cant find what i want...
I need only 2 front tires for the track size: 190/60/14
post up some websites where I might get something cheep just for a few runs on the track...
Thanks
Old Apr 19, 2004 | 03:33 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You might be having problems because there's no such thing as a 190/60-14 tire.
(Stock size is 195/60-14)
Also if you're replacing just two tires, you should always put the fresh ones on the rear of the car. Putting the fresh ones on the front can make the car tail-happy and more prone to snap lift-throttle oversteer.
Old Apr 19, 2004 | 03:42 PM
jockJDM's Avatar
jockJDM
Banned
correct me if i'm wrong but wouldn't it be better to put the new tires up front for a front wheel drive car?
Old Apr 19, 2004 | 05:32 PM
Tobra's Avatar
Tobra
Reread his post, it can make your car tail happy and handle a bit squirrelly. I would put the good tires on the front and slow down a bit. You can not go wrong with yokohama,
Old Apr 19, 2004 | 07:41 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
That line of reasoning does have a nice ring to it, eh?
Basically it comes down to what exactly over- and understeer are.
Oversteer is when the rear tires break traction before the fronts. You point the steering wheel a certain angle, and the car turns farther than you intend; hence "over" steer.
Understeer is when the front tires break traction before the rears. You point the steering wheel a certain angle, but the car doesn't turn as much as you intend; hence "under" steer.
Oversteer is generally considered to be a more uncontrollable problem than understeer, especially on a front wheel drive car. Here's an example of what can go wrong.
You're driving on a highway offramp at a reasonable rate of speed, then notice a bunch of cars up ahead are going to make it tough to merge. Your natural reaction is to immediately get off the gas pedal, and perhaps even step on the brake. When this happens, the weight of the car pushes down on the front wheels more, and gives them more traction (the car's inertia means it will want to continue going forward at the same rate of speed rather than slow down like you're trying to do). At the same time, the rear tires have a bunch of weight taken off them, and they lose traction. Since the fronts have all that extra traction and the rears have less than normal, the fronts dig in to the road while the rear end whips around. This is called off-throttle oversteer, and now you're in a ditch. It's an inherent problem with front wheel drive cars. If you put newer (and thus, stickier) tires on the front of a car, the difference in traction front-to-rear will be increased, and the car will be more likely to bite you in the ass.
I could go into why oversteer isn't as big a deal on a rwd car but I've already gone on too long.
Old Apr 19, 2004 | 07:44 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Anyway back to which tire to get in size 195/60-14.
Do you want an all-season tire? A performance tire? How much are you looking to spend? What are the other tires you've got right now?
Old Apr 19, 2004 | 11:05 PM
IntegraR's Avatar
IntegraR
yea i ment 195/60/14
hehe
looking to spend no more than $80-90
Old Apr 20, 2004 | 04:21 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
There are 30 tires that show up in your size on tirerack.com and pretty much all of em are within your budget. You're going to have to be a bit more specific.
So...
What tires will you be mixing these with?
Do you need snow traction?
Etcetera.
Any relevant info would be useful.
Old Apr 20, 2004 | 06:12 AM
c_rogue69's Avatar
c_rogue69
wtf goes here?
here's how I see it, if I'm getting 2 new tires, I'd put them on the front since they'd be fresh and have a less of a chance of popping or leaking. I steer with the front tires, so I'd like new one on there.
Old Apr 20, 2004 | 06:33 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
See the little essay I typed out above as to why that's a bad idea.
