CEL/engine problem
Old Apr 19, 2004 | 02:43 PM
NOSon's Avatar
NOSon
Default CEL/engine problem
in my 95 db8, the CEL comes on when im driving for about 30 min on the freeway or if i floored it hard. when the CEL is on, i can't go beyond 6500 rpm. Why does the CEL comes on? Is it the engine going bad?
Old Apr 19, 2004 | 02:50 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You can check the CEL code with the following procedure: http://www.c-speedracing.com/faq/06.php
Post your results and we should be able to give some suggestions.
Old Apr 21, 2004 | 09:27 AM
NOSon's Avatar
NOSon
ok im getting code 22, which is VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch. How do i solve this problem??
Old Apr 21, 2004 | 10:55 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Most likely you'll need to replace the switch.
I've attatched the troubleshooting guide from the Helms manual for a code 22 for a more detailed explanation.
Just to clarify the location of where exactly the pressure switch is, on the first page of this file there's a picture that points to what part of the overall solenoid valve housing the pressure switch is. The solenoid valve is mounted to the cylinder head next to the distributor.
File Type: pdf
Old Apr 21, 2004 | 10:01 PM
NOSon's Avatar
NOSon
thanks a lot.
Old Apr 22, 2004 | 02:13 PM
tegon-gsr's Avatar
tegon-gsr
mine does the same thing
SpeedyGSR
TSX/03+ JDM/Euro Accord
10
Jul 4, 2003 01:16 PM
4wdcivic
Engine Swaps, Tech & Tuning
9
May 15, 2003 01:58 PM
undrgrndhaqer
10
May 14, 2003 07:14 PM
jaxrunner
May 4, 2003 12:48 PM
AadosX
Accord
11
Mar 14, 2003 09:53 AM
