difference between b18b and b18c rod's in length?
Old Apr 15, 2004 | 07:56 AM
pomansouth's Avatar
pomansouth
Default difference between b18b and b18c rod's in length?
is there a difference in the length of the rod, if so could i run b18c rods in a b18b if i replace the crank in the b18b??
Old Apr 15, 2004 | 08:31 AM
ragerized's Avatar
ragerized
dc4 ownerages
why would you want to run b18c rods in a b18b, the b18c rods are weaker.
Old Apr 15, 2004 | 08:40 AM
pomansouth's Avatar
pomansouth
because i am buying westcoaststyles pistons and rods(upgraded)H beam rods that claim to handle up to 900hp. the pistons are forged 9.5 compression. this is why, now can anyone answer the question that i want to know??
Old Apr 15, 2004 | 09:35 AM
AP2's Avatar
AP2
Moderator Alumni
Yes the B18B's rod length is longer, thus having the 1834cc's over the GS-Rs 1797cc's.
Ragerized, you're wrong on that. I don't understand where you got that conception considering the GS-R motor has one of the highest piston speeds around.
Old Apr 15, 2004 | 01:15 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
the rod length has no effect on displacement... thats stroke you're thinking of. Say you have a motor w/ 89mm stroke (like the LS) if you put 90mm rods, or 120mm rods, the displacement would still be the same, the piston would just be moving 30mm higher up
I personally have no idea what the gs-r/ls rod lenghts are though. :thinking:
Old Apr 15, 2004 | 01:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
The only problem I foresee is that the LS and GSR rod journals are different. From what I remember with my build, the GSR has a larger journal than the LS. Is this correct?
Josh
Old Apr 15, 2004 | 01:44 PM
LT's Avatar
LT
The deer had to die!
the GSR rods are not as thick and wide as the LS's. let's see if i can dig up some pictures....
Old Apr 15, 2004 | 01:52 PM
Kai's Avatar
Kai
Rotorphile.
Nope. The B18B rods are shorter, that along with a taller crank gives the extra displacement over the B18C.
B18A/B, B20B/Z: 5.394" C to C
B18C: 5.433" C to C
To use them you need to also use a B18C crank. It will fit and work fine along with B18C rods in a B18B block. Conversly, you can stroke a B18C using a B18B crank and rod set.
Old Apr 15, 2004 | 02:03 PM
LT's Avatar
LT
GSR rods:
LS rods:
Old Apr 15, 2004 | 02:04 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
First of all, we're talking about running aftermarket forged rods here, so any comparisons between stock rods aren't really relevant to this thread.
Anyway, the only way to run B18C-length rods in a B18B block is to also use a B18C crank.
Whatever savings you're getting on the pistons and rods over new units will unfortunately be more than superceded by the cost of a B18C crank. Just as a point of reference, MSRP on a new one is $988.02.
